iNSTALLED 3.73 THIS WEEKEND WITHAUBURN DIFF. I DID BUY A NEW SPEEDO GEAR, BUT I DO NOT KNOW WHERE IT GOES. I WOULD APPRECIATE DESCRIPTIVE INFO ON WHERE IT GOES. ALSO, IS IT DIFFICULT TO INSTALL AND WHAT TOLLS DO I NEED FOR THE JOB.
THANKS FOR THE HELP
Hey,
Its kind of easy.
Raise the car, Follow where the speedo cable goes into the trans. remove the one bolt and pull out...the gear is at the end of the speed sensor, that is where the cable plugs into and the sensor into the trans.
I have pics on my site if it helps
good luck
Its on the drivers side. Very easy to find.. well ive taking it off tons of times when the trans came out so i know exactually where it is. You got a 23 tooth correct?
SVT
