1 - 10 of 10 Posts
I think that is what it is called. Its the red stuff they put inside gear boxes and stuff.
I'd like to paint the lifter valley with it. Do you think I can benefit from it?
Yes, it used by many. You can find it at any good paint store. If they don't have it, they can get it. Make some calls locally. GE made it when I used it.
wow... I spent all day looking for some Glyptal... actually the white colored one, for a vaccum furnace we built at work....
But, the red stuff is easy to find.... call local paint stores... or go to www.glyptal.com (GE doesn't make it anymore)... get their phone number, and have them lead you to a local distributer... Its also sold under the name Insulating varnish... Which I used for my lifter valley....
If you can't find it locally, go to www.speedomotive.com (they advertise in MM&FF), and get their number, and call them... they will ship you out a can....
eastwood.........
The place that did my machine work www.5oproshop.com , also painted my block in the valley with Glyptal. I'm sure he could get some if you needed it.
sorry to hijack the thread but what exactly would be the benefit of painting the lifter valley...and why use this stuff to do it???
im with 85 mustang, is it to make it look pretty when the motor is apart??
No, it helps with oil drainback. After you get done painting it and the stuff hardens, the surface is slick so the oil just runs right off instead of puddling in the valley. My friend had to use it when he had his TFS valvecovers polished because oil was seeping through the aluminum. A few coats on the bottom solved the problem.
1 - 10 of 10 Posts
