Can you fit a 10 inch rim on a fox? Will a 26x10 slick work on an 8 inch rim if you take off the quad shocks?
Yes you can fit a 10 inch rim under a foc. It may take some MASSAGING depending tire size. Also the correct backspacing is atleast 6.5.
A 26x10 inch should work with the quads if the 5.5 BS is used. If not, toss the quads. I havnt had mine for years on both the street/strip. You can also FLIP them around for a little more clearance.
Hope this helps.
Mike
