1 - 1 of 1 Posts
When I had the car up on the rack doing some oil and filter, etc. I realized my tires seem to be wearing wrong. The Outsides seem to be darker, than the middle, about a 1/2 inch on each outside, seem to be just on the fronts. The alignment must be wrong, my tire pressure is the same as my last set of tires which had a great wear line. So before I go get an alignment I was wondering what alignment you suggest,
my Hotchkis caster/camber plate instructions suggest the following.
Toe: 1/16"IN
Camber: 1/2 degree negative
Caster: 2 degrees positive
Does that sound right?
Thanks for any help you can give me!
1 - 1 of 1 Posts
