If you install push rods .150" too long and run the car a couple of times in the garage for about 2-3mins, what's the worst damage this could inflect on the valve train? Just want to know before I install the right size and run it again.
Discussion Starter · #2 ·
BTW I do know the engine runs like crap w/ wrong length, thx.
Discussion Starter · #4 ·
So I should perform a compression test (or is this called a leak down test)? Can a compression test be performed by hand cranking the engine?
