You can also use the Ford idle adjustment plate that fits between the TB & IAB. It uses two plugs with allen heads on them and is a bunch easier to get at! Dealers used to ba able to get them under F2PZ-9F939-A.
Hi,
I'm in process of cleaning engine bay and in the meantime, relocating wiper motor in the cowl. I want to have wipers working as stock because my car is still a street car.
Is there some of you that has done this and how did you complete the project? Do you have pictures of what you have...
A few weeks ago I bought my new 1986 mustang notchback, 4 cylinder, auto with only 1 owner. I plan on doing a 5 lug swap, but I cannot seem to figure out a good set of wheels for it. Any suggestions?
My speedo has never worked in my car even after new cable and sender ect. Was looking to upgrade to a Florida 5.0 cluster
with a GPS speedo.
My question is, how dose the factory cruise control work? If i eliminate the factory speedo/cable ect will i loose the factory
cruise control function?
EDIT/Cliff's Notes: This thread was originally called BAD Misfire, and the whole thread of diagnosis is intact, but if you go to posts 30, 31, and 39, you'll learn how to easily make your own smoke machine for finding vacuum leaks.
Short story--
New distributor and all...
I'm trying to get some ideas for my 89 coupe. I'm going to reupholster a set of Corbeaus and possibly the door panels. Does anyone here have pictures of their redone fox interiors?
