Status
Not open for further replies.
Shopping for a tremec but I dont know the difference between a 3550 and a TKO other than the TKO is more expensive.
Please call me Mike
tko is stronger and uses a different input and output shaft. For about 90 percent of small block (302 and some 351's) a tremec 3550 is fine
The TKO is stronger BECAUSE it uses a bigger input and output shaft. In fact, mine is a 1/2 TKO because I replaced the 3550 output shaft with the TKO output shaft. Gears, etc. are identical between the two.
Note: the tailshaft housing has to be re-bored to accept the larger bushing and seal that the TKO shaft uses.
RobKong
Status
