1 - 11 of 11 Posts
I found a set of 351 D0OE head that have had this done to them.
Milled
1.94 intake and a 1.? exhaust.
ported
3 way valve job
Tapped for studs
A new valve job and seats.
new springs that are good up to a .600 lift.
I know i will need the 1/2-7/16 bushing kit and guide plates with studs, stud mount rockers. Is there anything else that I might need to do to to the heads to make them work before I get these heads. I'm on a budget and these heads fit right in to it.
I think you have it all. The accessory bolts might be a tad smaller on the older heads. Let us know how they work.
Besieds the acc bolts and possibly new push rods can you guys think on anything else?
New stud mount rockers.
I had those listed.
Make sure that you use hardened pushrods even if the ones you already have are the right length.
New spark plugs too. the older heads use the larger spark plugs.
Thanks for the help guys.
1 - 11 of 11 Posts
