Can the springs on a 96 GT be changed out in the driveway with stands, a jack and hand tools? Ive put coil overs on a honda this way, just wondering if air tools are NEEDED. Ive heard a spring compressor is not required either. Thanks.
-Beau
I did mine in my driveway, with nothing other than hand tools, two jackstands and a jack. I did need a big hammer to drive the bolt out where the lower control arms bolts to the axle.
Yes, it can be done. Do a search for "springs" or "spring install" and MFE for the username. There is a ton of info on here about swapping springs - A quick search will get you all you need to know. :)
Wade
