Hey - something is up with my idle. I am wondering if my IAC is bad?
When I first start the car it surges like mad. From like 500 - 1200, sometimes it goes low enough it feels like the car is gonna bog and die, then I rev the car to like 4000RPM and let off....then it is fine :confused: When I put the clutch in at a red light, the rpm goes up slightly - so I thought maybe it was a vaccum leak - but I don't see one.
I cleaned the MAF with some quick dry electronics cleaner....it is still doing it.
What is up with this thing - it is pissin me off.
-Rob-
:mad:
Do a search for surging idle. This has got to be about the most common mustang problem. My bet is that your TPS is set wrong or your EGR is dirty/faulty.
Well I installed a new 70mm TB and for some reason we could not get the correct amps that the TB required. I think it wanted between .8-1.0 and I got like .6
When I talked to a few people - they said that should not be the problem.
-Rob-
you mean volts, anyway your going to want it a .97, you might have to take the tps off and reset it, try adjusting the idle screw on your TB that will also adjust the tps.
