Reverse is out in a buddies 94 5.0 and it may be cheaper to find a used one rather than fix this one. Will only a 94-95 tranny work or will the older T5's work?
thanks
Mark
You can use a Fox T5 if you swap your buddies input and bearing retainer (SN95) into the Fox...Be carfule of the loose rollers in the input though...
The SN's are ~5/8" (15mm) longer inputs...
Not sure if you'll wanna do this, but if you can find a fox bellhousing and clutch fork, you can retrofit the older trannies. Those two pieces compensate for the difference in input shaft length. BTW, if someone tells you this can't be done, they're full of beans. We have a 95 GT T5 in our 91 LX, and it was done using the process described above, just with 95 hardware rather than Fox. :)
