I have run a Moroso before.
Worked ok, but would not run it again for a street car.
They are just not made to last for very many miles before needing rebuild kit.
I've been thinking of installing an electric one now.
People use electric smog pumps off '98 cobras and some cadillacs i think
Seems to work very well and you dont have to worry about trying to
incorporate it into the belt system.
Make sure you get a vacuum regulator too so you dont pull to much
vacuum on the crank case. Moroso makes a good one that you plumb inline
no matter how "complete" the marketeer say it is,...it allways needs some fitment and hose work to end up the way that you want it.
with the mirad of other quap that is bolted on to the front of the engines....
no one maker can take all into account.
Discussion Starter · #7 ·
289 nate i was going to ask the same myself. kato the only thing really on the front my engine is the alt and a electric water pump as far as accessories go
