Has a 347 with 9:8:1 compression DSS short block, screw in core plugs, TfS heads old Hi port, comp cams cam shaft Harland sharp rocker arms. Edelbrock rpm 2 intake, AODE trans with up graded clutches an stub shaft Bauman controller PI torque converter, 355 gears with a on3 turbo 70 mm.runs strong just over 500 rwhp on 11 psi of boost. Comp cam custom ground something like a 292x extreme cam almost a 600 lift.
So I just bought this car I know I ask alot of ? S on here and and have learned alot .I want to upgrade this to E85 car so it has 60 pound inj now going to go to? 80s or more? Has a 320 with a boost ta pump ? Go to a 450?
I'm puting the A.c back in the car so 76mm turbo is about as big as I can go.
I'm willing to spend money on the turbo so what are your suggestions on this new refind build?
Keep in mind it's a street car and I dont plan on puting a cage in it so street turbo .
