1 - 1 of 1 Posts
I have the Explorer upper and lower intake and the 65mm TB. What TPS sensor do I use for this TB?? I went to some ford dealers and the service dept in each one was really crappy! One guy brought out a MAF and sensor and is like is this it?! I was like no fool the TPS! Anyway, the difference between the stang TPS and the Explorer is the mounting holes...on the explorer the hole are further apart so I can't use the stang one unless I drill it out a whole lot and then I can't adjust it well. Has anyone experienced this and solved the problem?
1 - 1 of 1 Posts
