:confused: Not sure where to go from here. My 94 gt AOD has 115k on it. I have cold air intake, 3:73, ud pullies, x-pipe, flowmasters thats it! I'm looking to spend around $1500 bt spring. what mods would get me going. I do plan on getting a s/c in the fall. Parts should reflect that but, should still be usable until that time. help would be great. If any quality parts are out there let me know.
Lots of things that you could do
I would say a set of heads such as AFR's or whatever you would like. But, there are a lot of other things that you could get. What you are including in you buget for the supercharger? You should get a bigger fuel pump, adjustable fuel presure regulator, injectors, MAF, headers, ignition, and some sub frame conectors. Thats just a start, there are plenty of thing that would help. Good luck.
you could probley convert to a 5 speed for 1500$ and maybe have enough left over for a set of headers or somethang.
Intake manifold and headers would be a good choice and you would still have a nice chunk of money left over
I would get some full-length weld in subframes and look at then consider some heads. That should just be about use the $1500 up.
