GT 40 upper and lower. non egr ported to match my dugan performance edelbrock performer rpm ported heads, im going naturally aspirated what size tb should i go with, i was hinking 70mm
I would say a 65mm throttle body would work just fine. You can always go with the 70mm also not much of a difference.
I ran a 65mm TB on my GT-40 intake then swapped to a 70mm at the track. On back to back runs, with the identical 60ft time, I ran .002 and .01 mph faster w/ the 70mm :rolleyes:
Either one should work just fine.
Good Luck
Brian
65 should be good, drop some juice on it or blow it, id do a 70
im going to do a 70, for the future setup with 24# injectors, and a matching MAF, maybe even larger then the e303, im ganna need high duration right??? both of the guys above me have some fast 5.0s, what cam would you recommend? maybe even some dry ZEX
Match the TB to whatever size the GT40 intake opening is (70 I think?) and get a larger MAF than MAF something like C&L 76mm.
