1 - 9 of 9 Posts
autometer has sent me 2 fittings that say they are 1/16npt. they will not fit. it is the same size as the od of the schrader valve and not the core. do you have to get a coupler from somewhere?
You did take the schrader valve out right? You need to unscrew it from the fuel rail and then screw the fitting in it's place.
the od of the autometer fitting is the same as the od of the rail fitting. like the outside. the cap will screw on the fitting they sent me.
i was just doing a tune up on a 99 f150 and was looking at the schrader valve and saw the the other part came out. looked at the stang and its the same. stupid me. i didnt even look at that part. i thought the core just came out.
1 - 9 of 9 Posts
