Here is my combo: 348 CID A4 block, TEA ported TFS heads (304/227 cfm @ 0.6"), AFM B-451 cam, Holley Systemax II intake max ported, Accufab 75mm throttle body, 83mm Pro-m mass air, Vortech YS-trim blower, AFM power pipe.
I currently have BBK 1 5/8" jet hot longtubes and 2.5" exhaust all the way back through some flowmaster 3 chamber mufflers.
I plan on running big boost with a cog pulley setup.
Thanks!
Discussion Starter · #2 ·
I would consider a 1 3/4" primary to 3" pipes to be the minimum. Actually the best setup would probably be 1 7/8" primaries to 3.5" pipes, but it will be pretty dang loud and probably cost 2-3 times more...
Billy
Discussion Starter · #4 ·
Thanks for the advice! I was pretty convinced that I needed to go bigger. The only question is how much. Do you know the relationship between pipe diameter and power level supported?
