I have yet to perform a single modification to my `99GT convertible, although the previous owner put a set of Flowmaster 3 chamber mufflers on it. Nothing else is done. Where would be a good shift point? Will this vary depending on what gear?... and if so, what gear should get what rpm shift? (approximately)
I shift around 5500, maybe 5600 - 5700 for you?!?
5250 is peak hp, so shift at like 5400 - 5500.......
Dave
Do you still have 3:27 gears?? If so and you shift around 5300-5400rpm you'll go through the traps in 4th gear.......if you shift at redline you can go through the traps in 3rd gear.......your choice. I always went for the redline shift when I was stock geared.
Discussion Starter · #5 ·
Thanks, guys. Yep... I still have the 3.27 gears. I have yet to take the car to the track and suppose I'll have to experiment with "fourth gear or not" come the traps. I remember running my bone stock 3.08 geared 5spd `89 GT and even though I could EASILY run through the traps in 3rd gear, I would actually get the tiniest better e.t.'s by banging it into 4th at about 4,800rpm- JUST before the traps.
But thanks for the advice on peak power ranges. This is my first modular Stang and it feels quite a bit different from my old five liter cars.
Dale
