What Oil Dipstick tube?
My oil dipstick and tube are pretty much shot cause of the heat of the headers over the years. Where can I get a new set-up besides the expensive dealer? What other cars had the same length setup that I can pull from the junk yard? I need to tube more than the dipstick. If anyone has one, I'll take it off your hands. It still must have a good bracket that bolts to one of the header bolts.
Thanks.
I'm sure just about any newer 5.0L would have the correct dip stick. I know the older one's had the tube going into the timing cover instead of the block (like early 70's or so), but that would be obvious. Just go out to the junk yard and start looking. Good Luck.
