1 - 12 of 12 Posts
Hey fellas! I am currently in the search for parts to get me to the 420-450 RWHP mark, so far after my dissapointing dyno I have gotten a 3.40 RR pulley, Gatorback belt, Magnaflow Exhaust (going on tommorow!), Intake spacer, and thats all for power, also Im still waiting on my boost pipe. But I need help in getting me to that mark before cracking the engine open, so what can I do before I have to take the valve covers off ?? I know I can get an intercooler and Im also ordering an O/R X-Pipe along with equal-length headers. Any other ideas ??? :confused:
I MUST GET TO THAT MARK !!! :evil:
MORE POWER, MORE I TELL YOU !!! :evil:
You can hit the 420 mark easily with the S-Trim running 14 psi, and just about all the mods in my sig.
To be honest with you I WOULDN'T want to hit the 420 mark on the stock block. Mine did 407 the first run and I almost had a heart attack and made them pull timing out of the car. It's not worth the .2-.3 you will see at the track unless you are serious about racing. I know there are guys like sting (awsome guy) who is hitting 420 and above on the stock block but in the end it comes down to "can you afford a rebuild when the stock internals let's go?"
Well my car is also not a daily driver so I only spin it above 5k RPM's seldomely, so Im not to worried about the stock internals, but Ill start ordering parts for the biuld up very soon!
Pics of my car ???
Any other ideas ??? TTT! :confused:
Alright, well I have ordered long tubes and a matching catted H-Pipe, so I will stay with that combo for a while, I will utleast be hoping for above 400 RWHP. Becasue if the Q400 can do it, than so can my car! I hope! LOL. Thxs, if anyone has any other ideas please let me know. Im also getting an intercooler down the road. Thxs again!
I thought the Steeda cars were good for like 350-360rwhp, 400 was at the flywheel. I think 400rwhp is if you add a Bullitt intake and Novi 2000?
Keep in mind I could be wrong.
I think the Catted h-pipe and longtubes will gain you about 20-25rwhp, the boost pipe should add another 10-20rwhp, the Magnapacks should pick you up 5-10rwhp, and the smaller pulley should pick you up 10-20rwhp.
In a perfect world you should see 410rwhp, in a ultraconservative world you should see 380rwhp - split the difference and you would be at 395rwhp.
One thing to remember is peak rwhp/rwtq is not the whole story, especially with long tube headers, you are going to pick up tons of rwhp and rwtq under the curve.
When I added my magnaflow catt3ed x and powerpipe I gained 22rwhp and 14rwtq peak, but under the curve I gained as much as 30rwhp and 25rwtq at certain rpms and showed increases from 3000rpm all the way to redline.
Also, I only make 368rwhp/360rwtq SAE, not huge #s, but enough to make me very hard to beat on the street - although like you I am always eager for more power.
Good luck and enjoy the boost,
Howard
Thanks for the info! That makes me feel a lot better actually! But I need to get doen to the bottom of the Q400, do they come with 400RWHP ??? Anybody ???
you could do it with my setup plus longtubes. Like rancid said, I feel much safer at 400 that I would at 430 with stock engine.
Discussion Starter #12
Nice numbers, I think Ill shoot for that (being realistic) but the intercooler is a bit of a way down the raod.
1 - 12 of 12 Posts
