1 - 11 of 11 Posts
Compared to what i have now (sig) what do you think i should run
I'm looking into some 15's right now for better traction or i might go with an eaton with 31 spline axles. Not sure just yet.
What are your times now? I wouldn't get the posi and axles unless it is already starting to go. With an automatic and no high stall converter I don't think you will have to worry about hurting the rear end. The 4.10's should take at least 2 tenths off maybe more.
i'm not sure on a real time slip, but before i took out my rear steat i think i ran a 9.98 in the 1/8 mile , my one and only time i went to the drag strip
I think after a little more practice and 4.10's you should run mid to low 14's. It just takes time to learn your car and be able to get a good run.
I was acually a tenth slower on Street tires after my 3.73s, because i couldnt get traction......make alot of runs and get some practice.........
Dave
I actullay lost a tenth of a second too. Someone told me that 4.10 don't do that much for the 1/4 unless you have a power adder...... So I got a turbo.
when you get 4.10s spend the extra money for LCAs, and subframe connectors with some ET streets. launch that like no other. Im sure you would see low low 14s possibly high 13s, i have a 97 GT 5 speed. at the track i hit a 9.665 with MAC offroad H pipe, and flowmasters. that was with stock goodyears with a 2.25 60' time. now i got the mods in my signature and I plan on busting a low low 14 with the addition of 4.10 gears.
Just for the record, this is not the original RavenGT. The original, me, had a black 2000 GT, hence the name, Raven.
joe
joe
Yeah, I figured that much out, Joe. I was waiting for someone to chime in about it. But, I'm sure most of us knew that you wouldn't be asking about 4.10's. :D
1 - 11 of 11 Posts
