Believe it or not, out of 8 Fox Stangs this is the first time I have had to install a heater core.
I remember seeing the article but do not remember the issue. I would just like to look at it before I begin the process.
I remember that issue. But I really couldn't tell u which one it is though. But it's not that bad. I took the dash loose. I didn't take it off. Make sure you unbolt the h-vac box from the fire wall, the nuts are located on the air dryer, passenger's side. This will allow the the box with the heater to fall forward.
Make sure you unbolt EVERYTHING. When you are pulling the box forward be sure to clear the wires that run along the pinch weld. When you pull the box you will be pulling the AC lines up against the firewall. Remember, it can be done without discharging the AC system!!!!!!!
