1 - 20 of 27 Posts
Best is in the sig and here is my list...hehehe
2000 Bright Atlantic Blue GT
Dynomax Bullet Mufflers with Turndowns
VRS Offroad X Pipe
Bullitt Intake
Custom Intlet Tube for Intake
Cobra Dual 57mm Throttle Body
Cobra Alternator
Auto Meter 5” Monster Tach
Weld Pro Stars
Weld Draglite (drag only)
MT ET Drags 26/8.5/15 (drag only)
RCI Race Seats and Covers
Seat Brace
C&L 80mm Kit (removed air shield)
Rear Seat Delete
UPR Subframe Connectors
FRPP 4.30s
SVO Rear End Girdle
Steeda/ARP Race Studs all around
UPR Pro Series Adjustable LCA’s
UPR Pro Series Adjustable UCA’s
Air Bag
Driveshaft Loop
Centerforce Dual Friction Disk
FRPP Heavy Duty Pressure Plate
Relocated Battery
Aluminum Rear Firewall
UPR Blue Thunder Shifter
Switch to Bypass Fan
180* Thermostat
NGK TR55s
Steeda Pullies
Steeda Timing Adjuster
4cyl Fox Body springs up front
Lakewood 70/30 Drag Struts
Lakewood 50/50 Drag Shocks
Moser 31 Spline Axles
31 Spline Full Spool
C clip eliminators
Kaenen Fiberglass Hood
V6 Rear Bumper Cover
Mr. Gasket Hood Pins
Steeda Offset Rack Bushings
Removed Wing
Cut Fox Body Rear Springs
Removed Front and Rear Sway Bar
Removed Quad Shocks
Battery Cutoff Switch
FRPP Aluminum Driveshaft
Bill
See sig.
factory freak
here's mine... pulled the best time last night at t-n-t :) my GT is one of the fabled "factory freaks" and i feel it still has more in it... i ran the time below launching at about 1800rpm and spinning my ass off all the way down the track... can't wait to put on my control arms, subframes, and some d/r or slicks...
my goal is to break a 12 (even if it's 12.999) without touching the engine...
k&n filter in stock airbox
flowmaster 40 series with all stock pipe
Hypertech programmer
4.10 gears
[email protected]
see sig and I have videos of it in the sig as well. Again, a possible freak car. I can't wait to get DR's:evil:
See sig for times!(from last year before many of the mods) New times soon!
Mods:
Vortech SQ with 3.33 pulley, Vortech aftercooler, 42lbs injectors, KB BAP, ported & polished TB, Pro M MA, 3.73's, aluminum DS, subframes, steeda triax, M&M rear control arms, tokico shocks/struts, bullit intake, Cobra brakes, MAC longtubes, modified Bassani X-with cats, Borla catback, battery in the trunk, Nitto DR's, and tuned by Lidio Iacobelli of Alternative Auto. I am sure that I missed several things but I think you get the idea. Car dynoed at 399.5RWHP and 392.2RWTQ. Later Ron
See sig. The only thing freaky here is my inablility to get down the times with what I have. LOL!
I should get some SFC's
Best 1/4 mile time
[email protected] with 1.975-60' on Nitto 245/50/16 Drag Radials
'98 Cobra Conv't.
BBK Off-Road H-Pipe
Flowmaster 2 Chamber Exhaust
FMS 4:30 Rear Gear
MSD Spark Plug Wires
Denso Iridium Spark Plugs
March Pulleys
Pro 5.0 Shifter
Chris
Re: factory freak
4.10 gears
[email protected]
If yours is a "factory freak", then what is mine??
I ran better than that on my stock tires with less mods. (13.52 @ 100.1) All I had was the gears and WMS tube. If you count my subframes, DS loop, and axles, my car is probably heavier than yours is. My car weighs in at well over 3400 lbs with the stock wheels/tires.
Not trying to disenchant you, but I don't believe in "factory ringers". Not in this day and age. However, I DO believe in those special weather days that people don't share sometimes when they run a good number.
Keep it up man...it can only get faster. 12's without touching the engine should be cake.
Eric
factory freak + cecil mod hehehheeh (and mebbe a decent driver).
Enjoy!
Jeff
i pulled the 13.5 about 6:45pm yesterday... temp was about 75, always humid here...
so i'd say typical conditions and not abnormally cool or anything...
last time i weighed the car it came in at 3450 with me and a tank of gas... (of course spare and misc in the trunk)
times in sig. are from Norwalk Raceway about 3 weeks ago
See sig. I never launched the car hard prior to adding the N2O, even with the E.T.Streets. After the c-locker, 31 splines and 4.56's are in I'll do some 7K RPM N/A launches and shoot for a 12 on just motor.:D
See Sig.... This is in Street weight.... Spare..etc..
12.700 @ 111 mph See sig for setup.
1 - 20 of 27 Posts
