1 - 12 of 12 Posts
its somthing you put in your MAF and suppoadly it cleans out your system, supposed to be a good idea, cleans the carbon or somthing?
anyone know what it is or how it works? thanks!
What do you mean by carbon? Do you want to clean the MAF or try to get the buildup broken down in your intake and heads?
Nitrous will clean the carbon outta your combustion chambers :D
I think the Seafoam stuff is what you're wanting
Electric cleaner/ windex/ lacquer thinner and a cotton swab can be used to clean MAF. There is a good article with pictures at:
www.tccoa.com under the tech articles.
http://www.tccoa.com/articles/intake/index.html#
Combustion chambers and carbon buildup can be cleaned while driving with ATF. Add a samll amount to the gas tank and it will clean the build-up out as you drive. Start with a small amount like mixing for a 2 strokemotor (40:1 or 50:1). Too much and the car will smoke.
A procedure of misting water into the intake at a high idle is probably the best way to really clean out the combustion chambers, but you have to be really careful...
I have been told a 50/50 mix of water and alcohol in a spray bottle and mist it in the TB at about 2000-2500rpm... all the parts store stuff is junk, and doesn't do crap for cleaning.
skinny pedal on the right.
SSKiller is right. I slight mist of water will do the job well. Besides it is cheaper than Seafoam
1 - 12 of 12 Posts
