I agree.I'd think with nitrous you'd want good exhaust flow.
Not to lead this thread another direction, but Im not a fan of how they present the show.When using BoobTube celebrity videos are reference material, keep in mind, they never actually build "combinations" that work properly. They take an engine that's been sitting around the dyno room and throw all kinds of free parts they get from various manufacturers on it, do up some fancy camera magic and call it a "test"...
Changing only one "item" and calling it a valid result is bogus. Every component in the engine combination must be matched to obtain the best result.
I find a few of these BoobTube videos entertaining but some are flat out dangerous with their bogus claims.
Whatever....
Those BoobTube videos are done to get clicks and clicks equates to money for the actors and that's why they all do it. It's not to "educate" or enlighten.
I don't think it will hurt it on a 200 hit if the tune up and combo is right. few local guys here who have legit pump gas nitrous Windsors in fox bodies with just old mac 1 3/4" long tubes with the ball socket replaced with 3" v bands and full exhausts.. they run in the 5.50s-5.80 range.It weighs around 2800 with driver, 456 gear, victor Jr intake, cam on a 106 seperation angle. Goes 6.40s best in the 1/8 so far, some Victor Jrs ported that only flow 280 cfm max, maybe 190 exhaust, didnt flow the exhaust. Only shift 6500 max and has kinda a tight 4800-5000 Ati, Leaves at 4200 rpms best 60. Just seems the 1/3/4 be alot better N/a for him and his parts and probably run about the same with 2 inch on 150-175 shot. If its faster on then it has a head start on nitrous to run same ET even if looses a tiny bit is my thinking. I was going to lend him some hookers 1 3/4 to try. But he thinks spay the 1 3/4 will kill it . Just like other opinions.
Makes me feel a little better-i have mac's on my N/a windsor making roughly 625ish. Was always thinking i needed to go 1 7/8-doesn't sound like it for the 800 dollar difference unless it's a gain of 2 or more tenth'sI don't think it will hurt it on a 200 hit if the tune up and combo is right. few local guys here who have legit pump gas nitrous Windsors in fox bodies with just old mac 1 3/4" long tubes with the ball socket replaced with 3" v bands and full exhausts.. they run in the 5.50s-5.80 range.
Todd,
You may have jumped up to too big of a size in your primary tubing.
