1 - 17 of 17 Posts
Mine has 2.73's too.....but I think the VIN code should tell you too.
it depends stick or automatic? a stick would have came with 2.73 or 3.03 where a auto 3.27. If you have an auto 4.10's would be a nice jump, a stick 3.73's would be a nice jump.
And it is the axle code on the drivers side door that will tell you, not Vin.
On the door there is a vin tag. On the tag at the lower right corner there is a AX with a letter under it. If the letter is a:
2-3.55 Conventional Differential
4-3.42 Conventional Differential
5-3.27 Conventional Differential
6-3.73 Conventional Differential
7-3.07 Conventional Differential
8-2.73 Conventional Differential
A-3.63 Traction-Lok
B-2.47 Traction-Lok
D-3.42 Traction-Lok
E-3.27 Traction-Lok
F-3.45 Traction-Lok
J-3.85 Traction-Lok
K-3.55 Traction-Lok
M-2.73 Traction-Lok
R-3.45 Traction-Lok
W-3.73 Traction-Lok
Y-3.08 Conventional Differential
Z-3.08 Traction-Lok
Hopes this helps.
-britt
On the rear end there is a small metal tab sticking out of one of the diff cover bolts.That will tell you. My brothers 94 gt vert has 3.08's you might have the same.
3.73s are tweener gears. Get 4.10s or don't bother.
My 95 convertible had 3.27 stock. I put in a 4.10
I currently have 4:10 with TKO and V3. First gear is useless. I am putting stock gear back in.
1 - 17 of 17 Posts
