1 - 8 of 8 Posts
An Intake
AThrottle Body
Roller rockers
or a 2.5" catback
What is holding me back the most? The car just doesn't seem as fast as it should be. How bad is this stock stuff holding me back? HP and ET wise?
Right now my intake, tb and rocker arms are stock. My exhuast from my Prochamber back is 2.25" and it has Dynomax Super Turbo mufflers. I also have stock injectors and a stock fuel pump
My mods
Motor rebuilt with forged pistions arp bolts etc...
Crane 2030 cam
GT40P heads
Crane valve springs
Mac Long tubes
Mac prochamber
Dynomax mufflers
C&L 76mm mass air flow kit
under drive pullies
Adjustable fuel pressure regulator
Tremec TKO
Spec stage 2 clutch
Aluminum drive shaft
Pro 5.0 shifter
3:73 gears
MM sub frame connectors
That's a no brainer, definitelly the intake. It's the plug on a stock engine, replace that and your car will really wake up.
If I remember correctly there was an article in an old Muscle mustangs magazine where they did a test, added heads and cam first and kept the stock intake. They dynoed the car and it only gained ~40 rwhp over stock. They put a new intake on the combo and it put down close to 300 at the wheels.
ya, a cobra intake picked up 25 hp on stock heads, I bet you would get 40 hp out of it.
Ditto intake.
I think the old magazine article put in a cam and Edlebrock heads, to the tune of 6rwhp. The Performer intake added like 37 to that combo.
I'd get a Cobra or Edlebrock intake.
damn..i was running high 12's with a stock intake and Ederbrock heads with a b-303
i run 12.3 @ 114 with a stock untouched intake and throttle body.
I would definately go with an intake and some 24 pound injectors
1 - 8 of 8 Posts
