well guys i have a 1995 mustang gt 5spd... i have added some new things to it... k&n filter, or h pipe, and 4 new monroe sensa trac shocks on the back, im an experience driver. and im really hoping for 14.8x im gonna launch at 2500 rpms and shift at 5900
I think you'll be able to hit 14.8's. Although you'd better shift before 5900 rpms, since the rev limiter hits in at 5800 rpms. I'd recommend shifting at about 5500 1st-2nd, and about 5200 2nd-3rd. Also, depending on what tires you have, 2500 rpms may be a little too high to launch at. Thats what worked best for me. Just my opinion. Try your own different combinations to see what works best with you and your own car.
Good luck, keep us posted.
Andy
Andy
Rev limiter is @ 6250, but you better shift no higher than 5200 or all you will be doing is making a lot of noise. It's all what you can do off the line, if you can turn a 2.0x light 14.8 should happen, maybe slightly faster if you got a good one.
My best completely stock was a 14.87 @ 93.4 with a 2.03 60 ft on the stock tires, and you have a little more power.
Good Luck!
