What do you have to do to install a DriveShaft loop?
Just wondering what the process is to install it? Do you have to disconnect your Driveshaft, do you have to weld the driveshaft loop in to be legal at the track,etc...
They just bolt in. As far as taking the driveshaft out, it depends on what brand you purchase. There are several that bolt together and can be assembled around the driveshaft without removing the driveshaft. You must take the front seats out and lift the carpet up to install the bolts holding the safety loop to the floorpan....James
If you dont care about your carpet you could probably just drill right through. Thats what Im going to do as my carpet is clean , but being 14 yrs old and no ones going to see the 2 small holes for the bolts anyways.
