What do I need to hook up my alternator(from a 94GT) to my carbed 302(also from a 94, if that makes a diff)?? And where should I look for one??
You don't need a darn thing. When converting to carb, you remove the EFI harness, but leave the chassis harness in tact. Since your car (1994GT) came with a 130amp 3G alternator from the factory, the wiring is already up to par. Bolt it up, and wire it up using your factory connectors. Good to go.
Discussion Starter · #4 ·
I dont have the factory wiring, so should I get one from the ford dealer or somthin?
How do you mean you don't have the factory wiring? How do you intend to wire up your gauges, brake lights, headlights, etc? S h i t load of toggle switches? Just wondering...
Discussion Starter · #7 ·
I mean the alt wiring harness or whatever from the 94. So I need to buy another one or what?
