I have a 90 GT on which I just performed a head swap. I'm now running GT40 irons (milled .010), and the car had Cobra Roller Rockers on it (which I discovered on the E7s when I took it apart). I had the heads rebuilt with the Trick Flow kit, but used FRPP valve stem seals because I read a few posts saying the TFs can cause problems.
The valve train geometry kicked my butt for longer than it should have. I first tried to put the engine together using stock length pushrods, and when I went to start it, I could immediately hear excessive clicking (I didn't torque the rockers properly). I shut the engine off, took everything apart, remeasured the pushrods, and came up with 6.300". Ordered TF pushrods, put them in, used a marker on several of valves, and the geometry was about as close to perfect as I was gonna get without special ordering 6.315 pushrods. I called it good, had to use shims on most of the rockers with the majority torquing to 18 lbs. in between 1/4 to 3/4 turn, put everything back together once again, and started it up. The roller rockers sounded fine, but I determined I had a vacuum leak at the back of the intake manifold.
So this morning I took everything off again with the intention of using silicone instead of the cork gasket on the intake. I didn't wanna drain the radiator and have to spend another 20 bucks on antifreeze, so after I pulled the intake, of course some water got into the lifter valley. I got a roll of paper towels and began soaking up the water. While doing so, I noticed tiny pieces of what I'm almost sure, are my valve stem seals. I seriously wanna kill myself.
Any suggestions as to what I did wrong? I DID feel confident I had the valve train geometry correct, but fragments of valve stem seals seems to suggest otherwise. Are there any other reasons why this would happen? Thanks in advance.
