what cam would be the best for a 8.5 to 1 comp 347 with a t70 turbo? i now have the trick flow stage 2 and was thinking about changing it but would like to get some imput on it before i get the motor tore down to do it.
Is your motor based on a stock block? If it is it won't matter what cam you run because Stock block + Stroker + Boost = Broken block.
