1 - 13 of 13 Posts
I helping a friend set up his 88 GT as a strip car/ weekend warrior type of thing and I'm not too sure what kind of cam to suggest ( he's new to mustangs, and I've never even put thought into carbed cars-shame on me). It's either gonna have AFR 165's or Trick Flow TW's, Edelbrock or Weiand intake, and definitly longtubes. I'm just wondering if anyone here could help out too.:)
Comp cams have a nice little cam don't have part # but it has 220/224 @ 50 544/560 lift should go well IMO..Carbed..
One more vote for Comp. I use the NX264HR, adv. duration 264 I/278 E. Lift .512 I/E. Lobe sep 114. Works excellent with my carbed combo.
You may want to go a little larger than this, because I run an AOD and have stock pistons, so I had to consider that. Check out www.compcams.com , you can get a complete listing there.
Stay away from the FRPP letter cams. That is old school technology, and there is much better stuff on the market these days. (I had the E-cam:barf: )
Discussion Starter · #4 ·
Thanks, looks like a good cam (I'm searching the compcams online catalogue for that one right now- ah the joy of being able to run multiple windows:D ). Think that cam would do equally well with either a built C4 or a Tremec TKO?(he's still undecided about which tranny to run)
If he's got the cash, go custom. Otherwise, the above mentioned 220/224 comp cam looks good.
call comp cams cam help lline.
they will design based on need, and expected performance.
Just a thought
If I was to build anything that was gonna see a considerable amount of track time. Hard launches slicks etc.... I would go with a Old Toploader 4 speed. These things lived most of their lives behind big blocks in the early 70's I think they would do just great behind a small block. The only factor would be street driving
gearing etc.. visit http://www.4speedtoploaders.com/ Keen toploaders they have a complete late model swap kit even built trannies.
Luck !
Ralph
Discussion Starter · #8 ·
The car will more than likely see a good bit more street duty than it will the track, but his standards for streetability arent exactly picky;) Anyone have any dyno #'s or track times for similar combos, particularly 1/8th mile times since all of the tracks in the area are 1/8th mile for some reason:confused:. By the way, does anyone have any experience with the trick flow cams, they seem promising for the price.
I run a Ultradyne Cam 286dur/525 lift with TFS TW heads, performer RPM intake, and holley 670 street avenger carb. I ran a [email protected] on BFG drag radials last weekend with a 1.88 60ft.
Discussion Starter · #11 ·
Blue92: Great times! Do you have any port work done on the heads or intake? BTW, just noticed that you aren't all that far from me. Were you run at?
Another vote for the comp cam. I am running with an Xtreme Energy 274. Specs are valve lift: .555 intake, .565 exhaust with 1.6 rocker. duration @ .50: 224/232. 112 LSA
Well that 8.04 was at Music City Raceway in Nashville. I live about 40 miles N of Nashville. My heads and intake are stock out of the box. I just have parts that match really well with each other. If you have any questions just shoot me an e amil at [email protected]
1 - 13 of 13 Posts
