1 - 8 of 8 Posts
I tried to do a search but it wasnt working for me so here goes...
I just got done putting in a griffin radiator and ramcharger fan setup. Now I need a catch can for the track. What are you guys running and where did you mount them?
I am looking for something cheap and easy
Shaun
I bought the summit one and mounted it in the wheel well near the radiator fill. One little tip to avoid the scrutiny of tech officials is use a real catch can and mount it nicely. If you pull into tech with a mountain dew 20 oz bungied to the radiator, they will start looking for other cobbled stuff, and look at your car much harder.
Plain RCI 1 quart catch can mounted to the left hand frame rail for now. Nothing fancy but it works well and was pretty cheap.
86 4 eye, 410 stroker, holley sniper, T70 single turbo, lentech aod, xbrake, 3.55's, k member, 5 lug
advanve auto sells a little plastic one that can be mounted 2 ways with the brackets. well, they loosely define as brackets, lol. it costs
$6, great for a barf can, too. i've got 2 of 'em , side by side, right over on top of the frame rail. you can also see through them. you could also screw them to your shroud.
Empty bottle of brake fluid turned upside down for easy dumping.
I am using a stock coolant return bottle that is mounted in the left front fender behind the headlight.
I'm using the overflow tank off of a '78 Thunderbird. It is mounted where the stock airbox was and the bracket is even the one from the T-bird re-bent a little bit. Works fine and doesn't look to bad (It has been cleaned up since that pic was taken). Cost = free.
1 - 8 of 8 Posts
