Just wondering, if you've had your fuel pump die on you, what were the symptoms you experienced before it went out? Thanks.
Before my old T-Rex took a dump, it was VERY LOUD and you could hear it a half block away :evil:
Whenever I had a bad pump in the past, the engine would die when hot. After 10 min or so, it would start and run for 10-15 min, then got hot and quit again. It takes a LONG time to get home when that happens.
All 3 times, my pump was killed by letting the tank run empty a few times. Make sure you keep gas in there.
