1 - 9 of 9 Posts
im getting an off road h pipe later this week and was wondering what the lines on the pipe are from- smog pump? Do i need them or can i just plug them up on the pipe?
They are the smog pump lines. You can plug them up, but you should remove the smog pump as well.
It feeds air into the exhaust to help it be cleaner blah blah blah you get the idea. Use a piece of heater hose w/ two hose clamps to reattach. It isn't going to hurt your performance to hook it up.
I say hook it up.
Moderator
Or you could go ghetto and just plug it up with an old lug nut like I did :D
For whatever reason, if you DON'T plan to hook it back up, at least plug it, better yet, run a short belt, or even BETTER get rid of all the smog **** :D
If you don't plug it it makes an annoying sputtering put put put put sound :mad:
You'll have to pinch off the tube on your new H-Pipe as well if you don't use it.
It blah blah blah, puts oxygen(air) into the cat, to help burn the left over hydrocarbon(fuel). You wont be needing it with out a cat.
Yup! Its just an air line from the smog pump. For some unknown reason, mine came off the other day and I thought I had a header leak or a hole in a muffler or something, but after looking, the hose had come off the H-pipe. Not only did it sound awful, (tick tick tick putt putt putt) but the car lost some power.
Anyway, once I get off my lazy butt, ill go grab some rubber tubbing and clap it back together.
Dave88 - you are right - that is pretty ghetto!!!!! LOL.
Hey, are those FMS SS headers with Stage 8 locking bolts?? They look nice.
It is the oxygen line the changes your exhaust from carbon monoxide two carbon dioxide through your platinum catalytic convertor ok.....lol
Discussion Starter · #9 ·
another question, does it jsut bolt up or is there any welding involved? oh yeah...and what is the hts coating? thanks
1 - 9 of 9 Posts
