my speed shop is taking too long, i can't wait to put these in......
i order a install kit from him, all i know is it has bearings, shims, and a crush coller thing....
is it possible for me to get all this at like pepboys?
what do i have to ask for? what are the bearings called?
prices?
And the other bearings where the crush collar go are pinion bearings , they go on the pinion, the bearing the go on the dif are the carrier bearings . you could always go to a ford dealer and get them , remember you get what you pay for , and I dont think ford bearing are going to be that much more if any and at least you are going to get quality part.
lowside
The rear end consists of
1. 2 pinion bearings and races
2. 2 Carrior bearings and races
3. various shims
4. crush collor
5. axle bearings
6. axle seals
7. pinion seal
When installing dont forget to set your pinion depth and back lash with shims, if you dont you will get premature wear and or a howling noise......
