stock block
TFS track heat heads
TFS street heat intake
TFS stage 1 came
Crane 1.6rr
im buying 6.7 and 6.75 length rods without checking.. but ill also be buying a rod checker from summit at the same time.. whats the chances of 6.7 or 6.75 working?
why am i doin it this way? b/c ill be goin out of state to install everything.. i dont have the tools to do it at my house so i gotta hope and guess right without knowing
if anybody with TF items with similiar combos can please post me there rod lengths.. maybe it would give me a good idea.. or does those lengths seem close?
full combo.
TF track heat heads
TF street heat intake
TF full gasket kit set
TF Stage 1 cam
Pro-M MAS conversion 75mm bullit
Holley 190 fuel pump
3.73 gears
KFPR
New oil pan gasket
70mm TB
egr spacer
crane 1.6rr
Ford racing lifters
24# injectors
6.7 worked fine for me and 6.75 works fine for others. You will be fine.
