Ok I have them hooked up with the 02 harness with the sender wire for the low oil light. This harness is hooked up to the passanger side(right) 02. Other harness is hooked up to the drivers side (left).
The reason I question if they are hooked up is. I got a code 91 lean right side replaced right o2 still same code. I put the old sensor back in the right side. Then I put the new one in the left side ( drivers) on more check engine light. This seems backwards.
I just want to double check the are in the correct socket.
Discussion Starter #2
bump
someone has to know what harness goes to what o2.
