Beautiful car, now you need to post some 1/4 mile times. If it runs as good as it looks , it's going to fly.
I have the same wheels on my car with M/T 275/60/15 drag radials. There is a ton of space between the tire and in inner wheel well. The closest thing to the tire is the bump stop bracket. Guys have used a air hammer to remove them for more clearance. I swear, with the right backspace, you could fit a 12" wide slick in there. hahaDid they bolt right on or did you have to use the BFH on the rear inner fenders?
They have three different mounting pad heights for the RT-S wheels. There is a "high", "medium" and 'low' pad height. The rears need the medium pad height. The fronts with the "high" pad height clears the Brembo brakes. Weld's website has an application chart for Ford HERE. Very easy to read and understand.Any issue clearing the Calipers in the rear? Or do the RTS offer the clearance the other 15" aftermarket wheels don't offer.
