I think this is an electrical problem, it could be a fuel problem. But its the weirdest thing when i come up to a stop light or stop. The car just jumps between idles rpms, it goes up and down up and down between 500-1500 rpms but eventually it will shut off. but if i hit the gas and rev it up at a stop. it'll go away then after a while come back again. But when im driving it does fine. There's one problem of a little skip in 3rd and 4th gear at about 3500 rpms but i think it may be an unrelated problem. Also would like suggestions on what that could be. And i also tried driving and just put it in neutral and it doesnt do it then? just when im stopped.
Any Help would be appreciated.
Thanks, Grant
Any computer codes? Check engine light may not be on but there can still be codes.
Banned
list the mods from stock you have done or have
most idle problems come from some type of air mass modifiction.
