Honestly, if I was going boost with a blower - neither.
At 12psi you’re able to add probably 80% more power with a turbo. It’s more efficient and can generate less intake heat.
10.8 compression is quite a bit to start adding boost with this type of power adder.
If you are insisting on using the Weiand 174, I’d go with the 5.0. It will be happy down low and into the midrange, but will be inefficient and cause added unwanted heat.
if you’re ok being N/A I’d stick with the 347 and enjoy it.
if it were me, I’d sell the 5.0, sell the Weiand and buy an intercooled turbo system for low boost on the 347.
