if the "weak springs" result in valve float then yes...but not as much as they would affect your et...since your usually not at very high rpm in the first 60 ft.
thanks for the reply i use running @133 in 1/4 then the next week the car slowed dow to 128 and i lost 60ft. et and mph i checked everything but springs.
I would look more at the traction and suspension....
i was getting 147 60ft. then it started getting worse with one changes 178 60ft. niw how do you explain that.
