After heads cam and intake there is a little water comming from the right tail pipe... I tasted it and its not sweet at all. My oil looks perfect!! And no oil in the radiator.. Why would water come out then?
Thats what I was thinking but from only 1 pipe?
yup. It can come from one, or the other, or both. Really doesnt matter
Discussion Starter · #5 ·
Ok thanks..
Water's only coming out when you first start it up, right? After a couple of minutes running it should stop. If not it's something else.
Discussion Starter · #7 ·
Well, I started the car went about 1 mile down the road and filled up with gas ( while the car is running ) Water was not really comming out but the inside of the tail pipe is wet.. Now let me ask you something. If it was a problem what could it be?
