@stangjumper what is your power level, how much boost do you run and what size turbo(s)
Power level depends on boost. Precision 6466s. I run 4.5- to upper 20s psi, so far. Power 500+rwhp to 1100rwhp, for now. Dyno session got cut short. Haven't gone back yet.
I hate the open wg sound also. I made custom mufflers for mine. That was my comment of you not wanting to do what needs to be done (wg mufflers). Mine can not be heard at all.
There is no doubt in my mind that the wg being piped back into the dp cost hp and spool time. The more hp you are running (exhaust flow), the more it is costing you.
I have twin 3" dp's the whole way to 3" tailpipes. I also have cutouts under the car that open under pressure (with custom mufflers on them, can hardly hear them open). I can tell you at 7psi, it cost me 20rwhp keeping the cutouts closed. I'm sure it is 100+hp at higher boost levels. I didn't have time to test yet.
Bottom line, you want as much exhaust flow as you can get, period. At least that's why I spent all the money I did, to get the most out of the combo. Route the wg gasses away from the exhaust system.
I know on my old gts76 combo, a 3 1/2" dp was worth 50rwhp over a 3". Open dp was worth considerably more with quicker spool time.
