I ordered my Mac exhaust Lontube headers and prochamber for my AOD car. Have you installed them on an AOD car? If so tell me how to istall them? Any helpfull hints? I have heard you have to tilt the motor, if so how? Thanks Jake T.
it would be best if you can put it up on a lift.because the driver side header has to go in from the bottom almost vertical and even then on most cars motor has to be moved side to side and up. steer shaft has to be removed. on my car I also had to remove brake master cyl., having someone help hold things on top when you are under pushing and prying helps I have installed three sets of these and have not had to dent any ,they do get scraped a little bit ,I have always managed to get pass. side in from top although mac says they go in from the underside have patience,good luck
