on my 94-95 it seems like I might need a shorter belt because the tensioner is being pushed down almost hitting the other side of the belt. theres about 1/2 inch clearance.
do i need a shorter belt?
if the belt is new you can use it for a while but the belt you need is a 53.7" belt
you will also have to move the idler pulley over one hole on the tensioner bracket
i got my last one (dayco) from a local parts store, was about 30 bucks
just tell them you need a 8 rib, 53.7" belt, they should be able to get you it no problem
