1 - 18 of 18 Posts
My IAT is loose and I am worried about losing boost through it. I sealed it up with some silicone (its held in by a rubber grommet) but the silicone just detatched from the plastic. Any Ideas as to what I can seal it up with?
is the iat just sitting in the hole with some silicon holding it, or do you have alittle rubber gromet that helps hold it in place? if you don't have the gromet, i would get one.
later
On mine .i got a lightning IAT and drilled and tapped the blower pipe for it.The lighting IAT is threaded so no sealer or gromment needed.
Yea I should have done that but I already have a hole drilled with a rubber grommet in place.
Mine fit the factory plug.
Also black you can get a new boot cheap from vortech.
Do you guys think that relocating the IAT onto the discharge side of the blower could effect hp numbers being that If your maf is metering denser air than the IAT is recording it is not going to properly meter the air? I have heard that it is not necessary to relocate the IAT from a few other guys, but I had already done so.
Dude your numbers are fine .The car is running fine.Why mess with it.
The IAT located in the discharge side lets the ecu see the exact temp of the compressed blower air going into the intake.
If you have it reading the air in the maf pipe it could cause det because the ecu will add timing due to cooler air BUT have actual hotter air going into the car.
I just drilled a 3/8 hole in one of my discharge tubing clamps between pipes and forced the IAT in ......no chance of it ever coming out by accident.
You are to hung up on the numbers thing. Like white99 said, leave it alone. Actually if you car wasn't tuned for the relocated IAT, it will cost you power by pulling timing.
Sense I don't have a blower on my pony, what is an IAT, may I ask?
how will it pull timing if if you move the iat.....doesn't that just control the amount of fuel the engine gets depending on temp which shouldn't effect anything if moved but give a more true reading for the computer
it would pull timing based on the temp of the air entering the intake to keep everything safe.
It is a much safer way of getting a true temp reading of the air going into the intake. It has nothing to do with the MAF and the air being metered by it. With the IAT in the Discharge tube the EEC will get a more correct reading then if it's located in the intake side of the blower.
If the Grommet feels loose to you then get a different grommet that fits better. I would never put silicone around it or any other forgein material that might get sucked into the intake. Just get a Grommet that fits tight and you should be okay.
I seriously doubt that you are loosing boost because of it.
If the boost isn't enough just install a smaller pulley :D
1 - 18 of 18 Posts
