My 96 cobra shakes quite a bit when I am braking. The problem seems to lessen when I brake while staying in gear. Ive replaced the front rotors with slotted GRIPP brand ones and the brake pads. Also replaced the brake fluid. Nothing changed still shakes. Tire pressure is 30psi all around and tires are balanced and in good condition. Thanks in advance
I would raise the front of the car in the air, one side at a time, and grab each wheel. try moving it up and down, in and out, and twist it all around. If you have any slop you may want to look into a worn control arm bushing OR a bad strut mount/bearing.
Hope this helps,
Jeff
tie-rod ends. R&R
